- rhagfoExplorer III
N-Trouble wrote:
Do all four corners, not just the front.
X2! - N-TroubleExplorerDo all four corners, not just the front.
- ktmrfsExplorer III
Devocamper wrote:
Campteacher wrote:
Many on here have had good luck with Bilstein 4600 shocks (yellow and blue). I've had them a few times and have liked them. Summit Racing is a good source for them.
Kevin
x2 on the 4600's
x3. used the 4600's on the 04 for 150K miles, and put them on the 15 the week I picked up the truck. way way way better than the factory shocks. - DevocamperExplorer
Kevin
x2 on the 4600's - KD4UPLExplorer III had Bilsteins on my '07 SRW Chevy 3500. I liked them. I put KYB MonoMax on my '05 Chevy dually, I like them even better.
I don't know why you would want air shocks on the front. They are normally installed to help level out the rear with a heavy load, this shouldn't be necessary in the front. Even in the rear I think they're a bad idea. Shock mounts are really made to support weight but that's what you're asking them to do with air shocks. Weight should be supported by the springs, frame, and axles. Air bags do this much better than air shocks. - ksssExplorerI have the adjustable Rancho 9000 on my 06. I like them, I have had them on for four years now.
- HalmfamilyExplorerPut Bilstein 4600 on front and 5600 on the rear of our 08 in sig and made a huge difference. Both front and rear OEM stocks were toast.
- CampteacherExplorerMany on here have had good luck with Bilstein 4600 shocks (yellow and blue). I've had them a few times and have liked them. Summit Racing is a good source for them.
Kevin
44,053 PostsLatest Activity: Dec 15, 2025
