Ramblin' Ralph wrote:
Rig: 2006 GMC 2500HD with 2001 Lance 845 camper. Tires are Michelin LT265/75R16.
My door jam plate says:
Front 53 psi
Rear 80 psi
I have been airing up to:
Front 60 psi
Rear 80 psi
My axle weights with camper and loaded for long term travel are:
Front 3350 lb
Rear 5800 lb
That's just under my GVWR of 9200 lb.
Last summer I had my tires rotated when traveling and the shop said I had wear on the front (cupping IIRC) indicating not enough pressure. So they boosted the front to 70 psi (or more).
I'm getting ready to hit the road again for several months. What is the consensus on proper front tire pressure?
Thanks,
According to these numbers you have more than enough air in the tires . My 03 diesel calls for 60psi with 245's . With 265's they only need 50psi for the same weight. Something else is causing the cupping . It could be the roads , front end wear / alignment , or even just the nature of the particular tires .
