Ramblin__Ralph's avatar
Jun 17, 2019
Front tire pressure?
Rig: 2006 GMC 2500HD with 2001 Lance 845 camper. Tires are Michelin LT265/75R16.
My door jam plate says:
Front 53 psi
Rear 80 psi
I have been airing up to:
Front 60 psi
Rear 80 psi
My axle weights with camper and loaded for long term travel are:
Front 3350 lb
Rear 5800 lb
That's just under my GVWR of 9200 lb.
Last summer I had my tires rotated when traveling and the shop said I had wear on the front (cupping IIRC) indicating not enough pressure. So they boosted the front to 70 psi (or more).
I'm getting ready to hit the road again for several months. What is the consensus on proper front tire pressure?
Thanks,
  • You have your axle weights why not go with the inflation table for your tires?
  • 60psi should be plenty of pressure for your setup. Check a load inflation chart but probably good for at least 2500lbs per tire
    Many causes of cupping, feathering of tire tread and not all of them indicate anything is wrong.
    Infrequent rotation
    Curvy roads
    Too low of pressure, maybe for the sway with a camper or in general
    Bad shocks
    Bad ball joints
    Too much too little camber
    Bad alignment
    Not tailoring the rotation to how the tires are wearing.
    If the truck is in good alignment and good condition then it could be just wear.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    BradW wrote:
    When we hauled our Lance on our SRW trucks, I had less sway when we ran the front tires at 80 psi. Tires are part of the suspension and when the rear rocks side to side, the front does also. So anything you do to stiffen the front suspension helps, even though 90% of the added load is on the rear tires.
    I honestly never thought about the front tire pressure and sway before due to almost all of the weight is added to the rear. Hmmm
    Thanks,
    Consensus on the TC Forum? :) :) :)
    bradw
  • “Tires rotated every 5K with essentially similar wear.“
    That’s the key you are doing right, sbryan, IMO.
  • The truck's placard should have tire PSI recommendations for loaded and unloaded conditions.
    When I was fully loaded, I set the front to the truck mfgr laden recommendations while the rear was at the tire maximum. Under no conditions should the tire mfgr PSI be exceeded.
    If your tires are "cupping" then it is generally due to bad shock absorbers.
  • My F350 says for a fully loaded truck 65 front and 80 rear. It has worked well for me for the last 35,000 miles with the camper on board. Tires rotated every 5K with essentially similar wear.
