geekyguru's avatar
geekyguru
frozen water pump
We had a friek storm come through yesterday. My water pump is no longer working and outside lines are,frozen. I have full fresh water, but no go on pump working. I have now turned central heat on with lp gas water heater. Not sure if we are dead in the water now.
  • The temp gets low around here sometimes. I Use one of those drop cord lights with a 60 watt bulb that Mechanics hang on the open hood when working. I put it in the Bay where the Water pump is located. I havent checked it lately but it worked last year. If you have such a thing, you might try putting it in there and see. Hope your's will be OK. Good Luck.
    I had my water system freeze up couple times on my old trailer and the water pump survived. I think you will just have to wait and see after things thaw out.
  • Check the fuse for the pump in case it was frozen and blew the fuse.
