Cummins12V98 wrote:
Bottom line is filtration or lack of it caused many third gen injector issues, it had nothing to do with additives or not.
I see no reason to use additives plane and simple. Is that clear enough.
I don't think you understand what filters and additives do. While both improve the quality of fuel, they do it in different ways that aren't linked to each other.
Filters improve fuel quality by keeping contaminants like dirt, water, and air from going to your engine. Additives improve how the fuel combusts, add lubricity, and have detergents to clean carbon from the combustion process. There are some water emulsifier/demulsifier additives that either contain or separate water from/in the fuel, but they still do not filter it out.
So you see they do two different things and someone saying that they don't need additives because of their filters is just as silly as saying they don't need filters because of their additives. Hence the reason why I questioned why you brought up filters in a discussion about additives since they don't do the same thing.
Now if you would have said that you don't need additional additives on top of what the fuel supplier adds because you ensure that you always get top-quality fuel with a cetane rating for optimal engine efficiency/performance and has carbon removal detergents with enough lubricity. Then I can see that as a valid reason for saying that you do not need to use additives.
