cummins2014 wrote:
So you are talking mileage ,and some are talking the health of the motor. So claims on both sides . I guess I was lucky on the health side not using an additive, and sacrificed mileage ,I guess . Never used it to see if there was a change in the mileage on the 7.3 nor this 6.7 Cummins .
Additives can effect the health of your engine too. Although most talk about the fuel pump, but I am referring to buildup on your injectors. If you are using a top tier fuel then you likely don't have to worry about since it already has these additives in it. Keeping your injectors clean aides in both mileage and health.
I know on my BMW diesel that uses piezo injectors, they are more sensitive to build-up versus my Cummins with electronic solenoid injectors. Being that it is a small 2 liter diesel, you can really tell in when the injectors have build-up because I will feel a noticeable drop in power and see it in my fuel mileage records.
My Cummins truck on the other hand, I can probably run the worst fuel possible for months and still not feel a difference. Part is this might be due to the fact that my diesel car is designed to run on 50 cetane while my truck is fine with 40.
