ACZL wrote:
THANKS once again for the help gang!!!!
Fish,from my experience, I cannot drain the oil and remove filter at same time as I don't have a huge pan. Biggest problem I had prior to installing the Fumoto, was once factory plug was removed, oil shot quite a ways out (read.....one heckofa mess). If oil pan had plug on bottom or at an angle, would be better.
As you can see in this video once the oil from the sump starts to subside you can start draining your oil filter.
LinkBTW... There's nothing better than a good oil maintenance video.
