Colo_Native
Jan 03, 2017Explorer
Fumoto Valve
How many are using a Fumoto or similar? I getting tried of cleaning up after oil changes, what are the issues? I know they don't drain as fast possibly leaving sediment in the pan. Thanks
Cummins12V98 wrote:Exactly, trying to get a sample from the gush of oil when the drain plug is pulled makes one heck of a mess. I open the Fumoto valve, let it run for a couple seconds, and can easily catch a sample mid stream with no muss, no fuss. That actually was the main reason I thought about the Fumoto valve in the first place. I send a sample off to Blackstone Labs at every oil change.fj12ryder wrote:
I'll chime in on this one too. I have them in all my vehicles, except the bikes. They are perfect for pulling oil samples for Blackstone Labs. I always made a mess with the truck because the oil just gushed out and I always dropped the plug in the hot oil.
Up to you but samples are supposed to be taken mid stream as the first oil has more contaminants.
I don't trust people, very easy to let all the oil out. I use a milk pail to drain oil with zero splash or spills.
