Colo_NativeExplorerJan 03, 2017Fumoto ValveHow many are using a Fumoto or similar? I getting tried of cleaning up after oil changes, what are the issues? I know they don't drain as fast possibly leaving sediment in the pan. Thanks
RCMAN46ExplorerJan 03, 2017I use a Fumoto Valve on my Duramax.As for drain time I open the Fumoto Valve first. Then I grease the ball joints etc. By the time I am done greasing the oil is completely drained.I use the spring clip on the Valve to deter someone opening the Valve as pliers are required.Safety clip
Related ContentFumoto valve installFumoto ValveFumoto valve questionFumoto ValveDIY Oil Changes- Fumoto Valve
