How many are using a Fumoto or similar? I getting tried of cleaning up after oil changes, what are the issues? I know they don't drain as fast possibly leaving sediment in the pan. Thanks
I'm pretty sure all the Fumoto valves require you to pull down on the valve before it will turn. Some have an additional add-on lock that keeps the valve from accidentally being moved down and turned.
