Colo_Native
Jan 03, 2017Explorer
Fumoto Valve
How many are using a Fumoto or similar? I getting tried of cleaning up after oil changes, what are the issues? I know they don't drain as fast possibly leaving sediment in the pan. Thanks
RAS43 wrote:cummins2014 wrote:The_real_wild1 wrote:
No real drawback except for price.
No real drawback ? I too have one, and was curious about how much oil is left in there, well after draining until it stopped I pulled the Fumoto Valve the first time I used it . I can't say how much oil came out, but was a lot more then I wanted to leave in there.
For me I use it to drain, and then pull it to let it drain again .Eventually I will probably go back to the stock drain plug. Its nice that it allows to open up for oil analysis , although I don't do one, and it comes out slow enough you don't have to use a special pan or bucket.
I cut grooves in the end of the threads before installing the valve and it will drain fully in my application. I am sold on this valve.
