I don't have a Fun Finder but I have an Enterra which is also manufactured by Cruiser RV and has the same slide mechanisms/hardware. It also has the same furnace.
We moved the slides out and in many times when we first bought it in April and since then every weekend over the past month; they have worked great. Also we've used our furnace in the morning for the last two weekends and it too worked fine.
One thing with rv furnaces, you really need to purge the propane lines if the propane has been turned off at the tank(s). I do this by lighting each burner of the stove after which the propane pressure to the furnace should be ok (assuming that was your problem).
Similarly the fridge may require 2-4 restarts the first tine it has run on propane. After it starts once it should be ok after they.
We are very happy with the workmanship of our Enterra.
