RSD559
Jun 01, 2015Explorer
mobeewan wrote:
Do you have room on the tongue in front of the battery to mount a dual tank rack like this one?
Your regulator bracket can be mounted to the tank rack bracket with machine screws and lock nuts probably with the existing holes lining up.
I mounted one of the dual tank racks to the trailer tongue of a pop up and older TT trailer I have that had single tank regulators. I only used the pop up for 3 to 4 day trips. I could change the regulator hose from one tank to the other if needed when I didn't top off tanks before a trip and I could always connect a separate hose and regulator to the second tank for a grill or table top oven I carried. for longer trips I would use the trailer and swap the hose on the tanks as needed.
I thought about putting dual tanks on, but we really don't need them. Our longer trips are at hookup sites. We've never, in previous trailers used up a single bottle. So I think I'm just going to move the regulator. Thanks.
44,071 PostsLatest Activity: Aug 30, 2026
