Mikesr
Jun 28, 2016Explorer
2oldman wrote:
A google search of that thermo should give you the manual and the wiring. If your internet connection isn't good I can do that for you.
I'm assuming you've not done that already or you wouldn't be asking us. But it seems like every time I say this, the poster comes back and says he did that.
Thanks
Google turned up its the white wire for the furnace
What could be causing this ?
Bad thermostat ?
Furnace problems ?
After turning thermostat off and on and pulling fuse the original problem has stopped.
I did give the thermostat a light tap or two can that help or hurt ?
Was this caused by the thermostat running on AUTO and not on normal ON position ?
Thanks
