JOLLERO - Just for comparison as to what MARKW8 says above..
My three batteries gives me 255AH capacity. I have a good DC BATTERY MONITOR panel that monitors both 12VDC from the two battery bank setup and a 75AMP DC Current from what is being drawn from the trailer items.
I usually draw 20AMPS DC Current from 8PM to 11PM each night running all the 120VAC items from a inverter and direct connected to the 12VDC terminals. In addition to this I have a good 1-2 AMP parasitic drain from the batteries 24/7. This will drop my three batteries (255AH capacity) to around 12.0VDC at 8AM each morning which is pretty close to being a 50% battery bank charge state. This is where I must re-charge by connecting my on board PD9260C converter/charger to my 2KW Honda Generator and run it for three hours to get my three batteries back up to their 90% charge state.
Perhaps you can judge from this what you 12AMP drain from your furnace 12VDC blower is going to do to you before 8AM the next morning.
What you don't want to happen is to drain your battery down below 12.0VDC without re-charging again. This will do internal damage to your battery unless you get it charged back up.
You can look at the specs of your battery to determine how many minutes it will produce 12VDC to totally drain your battery.
consider this spec sheet for a Trojan T1275 150AH 12VDC battery
!fo)BRzzqTZsmQ~~60_35.JPG)
The spec sheet says you can draw 25AMPS for 280 minutes before draining down to 0% Charge rate. SO running down to just 50% it will only last for 140 minutes or just over 2 hours of use. Your 12AMP draw using this battery should last 4 hours... Then you must re-charge back up to 90% right away before doing internal damage to the battery.
All of this is not exact but sort of gives you an idea on how to determine how long you can survive with one battery.
Roy Ken
