Jollero wrote:
The Jayco pop up manual shows 12 amps is what the furnace uses...
I question the 12A number if indeed you have a Jayco popup. Can you tell us the make and model of the furnace to double check that figure?
Maybe you have a big highwall unit with a bigger furnace? My Baja uses the Atwood 7916-II (very typical popup furnace) which is rated at 3.5A. Basically the DC draw is from the fan motor.
How long the battery will last depends on:
- Battery capacity and health
- How cold it is outside
- How warm you want it inside.
Best case scenerio:
- Get the largest capacity true deep cycle battery and maintain it rigorously.
- Use reflectix window inserts and PUG bunk end covers
- Use the furnace conservatively - warm it up at bedtime then cut the thermostat back to 55 or so. Use warm sleeping bags or blankets. A digital thermostat will help with more precise temp control.
For a real world example, we spent four nights at 9000' in the mountains of Colorado. Overnight lows were in the low 40's / upper 30's. We used the furnace conservatively as described above (no reflectix or PUGs) and still had >50% state of charge on departure day. Battery was a Trojan SCS225 (130Ah).
