deehinson01
Dec 22, 2014Explorer
Furnace blower is not coming on
New to this RV experience. I know just enough to get me in trouble as my daddy would say.
My furnace blower doesn't come on. It is supposed to kick on within 15-30 seconds, then the burner is ignited and air is warmed.
I've googled my problem and have already checked off this:
1) check thermostat setting. My thermostat doesn't have an on/off/auto. You slide the dial. Done.
2) check pilot light. I have direct spark ignition. Done.
3) check the battery charge. (not sure)
4) check the propane. Done.
The question I have is this: If I am plugged into a dedicated utility line, will the battery charge make any difference?
If not, what else could be causing it not to come on? It was working fine Saturday.
