Does anyone know how many amps the blower pulls? The reason I ask is we've been awaken by low bat alarm while running on bat with the furnace heating the Lance. We've had the bat checked with a load t...
The real trick is to start at 100% charged battery. If you are charging with a generator make sure your converter is charging up in the 14.5 volt range. Otherwise 100w of solar will go a long way.
