Kayteg1
Feb 27, 2019Explorer II
Marcela wrote:
AGM works lots better then lead acid.
AGM IS led-acid.
Only thanks to mats between plates it can be used sideways, so if that is what you need in your TC, than you spend your money wisely.
I had the situation with battery running low at 4 AM and truck starting. I don't stay without hookups very often, so buying additional battery for 1 in 2 years situation doesn't make much sense.
So my idea is to use truck dual batteries for such occurrence.
Obviously you don't want to do it without back-up and the $150 inverter generator HD was selling is perfect backup.
44,071 PostsLatest Activity: Aug 16, 2026
