Old-Biscuit wrote:
That only controls the Cooling blower (A/C FAN)........
The furnace blower only operates when HEAT is selected.
Furnace blower only runs when furnace is operating.
Now you can run the furnace and have the A/C fan running (without compressor---cooling) to help circulate the air inside RV
Yep, however I have found like another poster mentioned if you put your electric heater in the area of the A/C and then run just the A/C fan on low that helps distribute the heat a little better through out the trailer sort of like using a fan to distribute the heat around when using an electric heater.
Larry
