Scott321968's avatar
Scott321968
Furnace issue.
I am the owner of a 264bh. We went for our first cool weather trip this past weekend and had a problem with our furnace not firing the second night there. Temps got down to 28 degrees. I had one tank full and another about half. Furnace tried to fire a few times and couldn't. The auto changeover valve didn't kick in, so I switched over to the full bottle and reset the furnace. Fired up fine. Couple next to us also had the same issue and used the same fix. My question is, how do I prevent this from happening again? Can bottles be heated with a magnetic oil pan heater or lines with a heat tape? Not sure how hot an oil pan heater gets. I didn't know if someone makes a kit for this or not.
------I posted the above on the Jayco forum and was asked a few questions so I will add more details below.----
The first tank was about 1/2 to 1/3 full. The lines were bled the day before and the furnace worked the first night in thirty degree temps. I did reset the furnace before tank changeover. Regulator assembly was replaced this summer due to a leak when new. We were on shore power. And, as stated above, the couple next to us in a Jayco 26 with slideout had same issue. He did state that his bottle was almost empty , but his changeover valve had not switched.
Someone on the other site suggested that the line might be bad and not allowing proper flow. We did have the stove and the furnace running together the first morning as well as the oven the second morning. Any ideas?
