NevrdunExplorer IIFeb 22, 2023Furnace on while movingWe are traveling in cooler weather and I am wondering if I can run furnace at the lowest setting while on the road? Assuming adequate power to run the fan and propane supply. Thank you.
stevenalNomad IIIFeb 22, 2023When traveling in sub-freezing temperature, the heat stays on low to prevent frozen pipes and doggies. No problems yet.
