lakeside013104's avatar
Nov 09, 2016
Furnace runs with dial set to OFF?
New 2016 Palomino Back Pack Edition TC.
Wall thermostat set to the OFF position. Out side ambient temperature at 32F.
Plugged into shore power.
Walked by outside of camper and heard furnace running. Went inside and verified thermostat set to off and found furnace running normally like it would if I had the stat set to 70F.
Is it normal for a furnace to run while thermostat set to the off position?
What to do to correct problem?
Lakeside
  • I probably should had explained better. I tried to keep it simple.
    I had stored the TC in about 50F weather and left it plugged into shore power as I planned to use it a couple more times hunting in the fall. Furnace was off and not running.
    Several weeks later, the temperature was around 32F when I happened to walk by TC and heard furnace running. Went inside and noticed thermostat all the way to the left in the OFF position.
    I called dealer and they told me to look for a separated OFF switch on thermostat or on front panel of furnace unit. None was found in either place.
    Called dealer again and was told to bring thermostat in and they would replace it. Hopefully with a better one!
    In the mean time I have added an inline switch between one of the thermostat wires. Does not look too pretty, but it is functional.
    Currently, when the switch I added is in off position, the furnace is OFF. No more using up all my LPG if I am not even in the camper to enjoy the heat!:W
    Again, RV.net folks have come through with some well thought out suggestions.
    Thank you all.
    Lakeside
  • AnEv942 wrote:
    ..Some thermostats, mechanical, lever just slid to bottom of scale doesn't turn it off. Lever requires a bit of force to continue and actually be in off position. The one that came with our camper felt like was going to break something before it snapped to off position.
    This one caught has caught us more than once. You would think we would have learned. :R
  • Did you pull the grate off the furnace unit? That is where my separate off switch was.
