mdprowash wrote:
Thanks again! I replaced the converter last year with a Progressive Dynamics 45A smart charger.. so it probably does a good job. The Genius on 6v mode does 7.25v - 3.5A
My next question.. If I bought a "blue or red" 2000 series generator.. I would need to use an adapter for the 30 amp cord to plug into one of these generators.. is that okay? If I brought my batteries down to close to 50 percent... how long would it take for one of these generators to charge them to near full capacity?
I have a similar setup in mine.  2 6 volt 208 AH batteries and a PD4045 converter.  I also have a trimetrics battery monitor system, so I have a pretty good idea of what's going in and out.  We were just in the Black Hills last month for a couple weeks without shore power.
Mine draws .6 amps with the fridge on gas and everything else off.  The furnace draws 6 amps when running.  We keep it cool inside, 58-60 at night with it around 30-40 outside.  We will typically use around 15% of the battery power each day.  I ran my Honda EU1000 for 1 1/2-2 hours each day to keep the batteries close to 90%.
The converter won't go into boost mode until the battery voltage gets below 12.  In normal mode, it would start out charging at around 20 amps and slowly drop to around 8-10 amps by the time I shut down the generator.  I called PD to verify that is normal, and they said it is.  No way to force boost mode.
Yes, I use a 30 to 15 amp adapter to plug into the generator.
