Prober22's avatar
Prober22
Fuse Blows on Bedroom Light Circuit
Hi Everyone,
My trailer is a 2012 Denali 265RL. About 4 years ago, when I would park in a new location, the 15 amp fuse on the Bedroom circuit would be blown when I got into the trailer. It was annoying. I just pulled the trailer out of the pole barn and the new fuse I put in blew immediately. The light in the pass through storage bay is on that circuit. I removed the fixture and unhooked it from the two wires.
There is no fuse in the panel now. With my multimeter, both wires complete the circuit while holding one probe on one wire and the other probe on the frame of the trailer.
If my electrical terms are not precise, go easy on me. I'm coach-able.
I think that the ground, or negative wire should cause the multimeter to buzz, while touching one probe to it, and the other probe to the frame. I think that the Hot, or positive wire should NOT cause the multimeter to buzz while touching a probe to it, while there is no fuse in place.
I think that the hot wire must be grounded to the frame somewhere. Does that sound correct? Given how the problem started out intermittently, and now is constant, I have this mental picture of the hot wire, at some point after it leaves the positive end of the fuse holder, being crushed against some part of the trailer frame, with damaged insulation. Does that sound reasonable?
Is there anything else I should check for before I start with trying to trace the problem?
My plan would be to disconnect all the power, remove the fuse panel from the wall, and then try to figure out which side is the hot side, and then start to trace that wire back to the bedroom lights, looking for damaged insulation on the wire.
Would the hot side wires be color coded differently than the ground side wires?
I would really appreciate any tips on how to fix this problem. Is there a way to test certain, unaccessible sections of the wire? Is it best to start at the fuse end on the wire and work toward the lights, or the other way around.
I am Twittering with excitement.
Thanks,
Jeff
  • Locate all the lights on the circuit and remove the bulbs. It is possible that some one put in the wrong type of lamp shorting the circuit in the lamp holder.
