Gjac
Mar 11, 2019Explorer III
FW capacity
I just started looking on line at TC's and noticed there are not many units that have more than 30 gals of FW. Those of you that dry camp most of the time which I assume most of you do where do you st...
steelhunter wrote:According to Fords web site a regular truck cab is 3270 lbs. I was going by memory which is not too good. That still seems like a lot for a 1/2 ton truck.Gjac wrote:[email protected] wrote:I just looked at your model online, looks nice with a dry weight of 2600 lbs, I am guessing that the traveling weight would be less than 3600 lbs, does that mean a truck with 4000 payload would be sufficient to haul it? Also I notice that the new Ford F150 with the 3.5 eng has a payload of 3700 lbs would this be sufficient?
We have a Northstar Igloo and we have 40 gallons of fresh water. What really makes that work for us is the cassette toilet, which has its own 5 gallon water supply and that can be used with very little water. We also carry jugs for drinking water and mostly use the FW thank for showers and dish washing. It's amazing how little water you can get along with if you try.
An F150 has a 3700lb payload?
