d1hNomad IIIMay 25, 2021Gain settingRecently bought a Chevy truck with the built in brake control. My question is what is the best setting for the gain? I'm towing a 27ft TT.
wanderingbobExplorer IIJun 01, 2021The adjustment is something you will do many times as conditions change , low line voltage , corrosion on the multitude of connections in the hundred feet of electric wiring , wear on the brakes , load !
Related ContentGaining AltitudeLooking to gain knowledgeCapitol gains tax?It gained weight.Gain setting on Patriot Brake system
