old_guy's avatar
old_guy
gallery grey tank
I just got a cougar 31rld and it has a galley AND a grey tank, any way there is a button to check the level in each in the kitchen. I only see two pull handles for valves under the TT one for grey and one for black. if any one has this TT, can you tell me if the one grey valve empty both of these tanks or am I missing one of the valve handles under the TT?
  • Ours is the same as TucsonJim's. One problem we discovered this past weekend is we will need a longer sewer hose. We had to use our 10 foot hose and our friends 20 foot. We usually have 20 feet but the other 10 foot section burned in the fire but we will definitely carry 30 feet with us. I wish the galley tank fed to the grey tank but oh well. I love having the extra tank.
  • I have a 26 foot and the galley tank valve is between the tires under the slide.
  • I'm not exactly sure about your unit, but my Cougar has the two handles behind the axle. One for the black tank, one for the gray tank. Then, it has another handle in front of the axle for the galley gray tank. The bad thing about this handle is that it's under the living room slide. If you want to pull it while you're hooked up, you either have to run the slide in, or you need to crawl under the slide to reach it.
