vynnp wrote:
OK, so if I wanted to buy the Coleman Road trip, all I would have to do is remove the regulator and then adapt it using the supplies you listed? I hate hauling those little bottles around when you have two 20# tanks and they were nice enough to put the quick connect outside in the cooking area
That is exactly what I did. I PULLED the regulator off of the assembly. I then grabbed fuel line and double clamped one end to the recently deregulated fitting. The other end of the fuel line was double clamped to the quick release assembly. It has served me well for two seasons.
