fallsrider wrote:
I will most likely check everything out again before I order a new regulator. Thankfully, we're not going anywhere with the trailer over the next 3 or 4 weeks.
Me, I try all options before I change stuff. If it were possible to open the valve up, disassemble or whatever, or blow a bit of air through the regulator ,maybe back flow i would try that. I had a small spider web in my gas line going to my heater. When the heater lit it billowed black smoke up the side of my Class C and I thought it was the end of it all.
The issue does point to the regulator and after 8 years of service I think that was a good run. Alternatives? they appear to be about the same.
