We had a whole debate about this topic on another thread. Most gas stations you'll be able to get in and out of, but sometimes you have to pull out your driving skills to maneuver through properly. Some stations don't make it easy, but you can always make it happen. We have the same size trailer and many times we pull in to a spot and then just back out of that spot instead of trying to make a loop.
The 1/2 tank rule is a good time to look for gas. Don't push it past 3/4 of a tank cause that last bit will seem to drop way faster than you expect. Running out of gas is no fun.
