Turtle n Peeps wrote:
Here's the deal.
If you buy a tuner and remove the torque management from the puter you're playing with fire with a stock tranny.
The torque management from the factory is there for a reason. It's there to keep the plastic stock tranny alive. The stock 4L80E's are pretty strong but the 4L60's are like playing with a bucket of snakes IMHO.
Now is it going to blow up with the first stomp of the throttle? No, not likely.
What did Clint say? "Do you feel lucky punk? Well do ya?" :B
I must disagree with this. Another reason GM uses torque management is for comfort. Most people don't like firm shifts, so GM maps the computer to reduce throttle and extend clutch engagement to make the smoothest shifts possible.
I'll use my 01 half-ton Burb as an example of everything I "did wrong" to it. Please pardon the minor thread derail; I'll try to bring it back around at the end of my post.
- I bought it used with 85,000 miles, in 2005. At 100,000 I flushed the transmission with 16 quarts of ATF. The horrors!
- Even with the 4.10 gears, the truck seemed like a dog to me. I also wanted to squeeze every little bit of power I could out of the engine, so I pulled the PCM and had it tuned for 91 octane by Charlie Wheatley down in Texas. Among other things, he removed 60-70% of the torque management. His testing also indicated I'd pick up 15-20 hp. So that puts me even closer to the max torque rating of the transmission. :E
- The change was noticeable - firmer shifts, better throttle response
- I drive the truck hard. When I'm alone, which is a lot, I'm usually driving it like I stole it.
- Since the tune, I've logged over 20,000 miles on that truck pulling the trailer that is in my sig. This trailer is heavy enough that I've had the rear end blow out on my twice while traveling. Also the main reason I bought the 08 2500.
- We don't camp in Michigan; it's always out of state. I've used that 01 half-ton to drag the trailer down to FL multiple times (so I've gone through the Appalachians), and we've also gone out West, as far as Yellowstone, so I've dragged the trailer over 9600-foot passes.
- The truck now has 185,000 miles and the transmission still shifts perfectly - no slipping or any signs of any problems whatsoever.
- I do try to take care of it. Prior to any towing, I installed an HD cluster to have the transmission temp gauge. The transmission usually runs 100° over ambient, regardless of duty cycle.
- I also tow strictly in third gear, minimizing stress on the transmission - in third it's a 1:1 ratio, so it's simply passing through the torque and power of the engine.
Torque management is much more severe on the GMT900 trucks. The PRIMARY reason for TM is comfort - not to protect the allegedly fragile transmissions. Right or wrong - smooth shifts are a luxury feature that most buyers notice.
I live near Detroit. Several of my friends are powertrain engineers for GM. I'd be happy to have one of them chime in as well.
