Reisender
Mar 12, 2020Nomad
wilber1 wrote:time2roll wrote:
Yes thanks for the HS chemistry lesson. All of the gasses contained in air go through the combustion cycle and a few things are created besides CO2 and water vapor due to the heat. Some of which are considered pollutants but that was not the point of the video. Gasoline contains some nasty stuff also but that is not the point either.
My point is the battery in and to itself releases the stored energy. Nothing else required. Gasoline needs to be fed oxygen from some other source to burn and release energy. My point is that all the elements to get the energy from that gasoline are not contained in that gallon jug.
Yes but from a practical point of view, an ICE vehicle getting 30 MPG requires less than 70 lbs of fuel to go the same distance as a Tesla S 85 with a 1200 lb battery. With 140 lbs of fuel, it can go twice as far.
All true Wilber but to be fair a gas motor, transmission, rear end, exhaust systym and large radiator all weigh something too. (I have no idea what though, 1000 pounds maybe? Total guess).
44,070 PostsLatest Activity: Sep 18, 2026
