lancekeys's avatar
lancekeys
gear changes for better towing
I just took a trip with my new fifth wheel and I am beginning to see that my truck is somewhat lacking in the power department. On even the slightest hills interstate overpasses my speedometer would keep dropping even with the throttle wide open. I don't expect miracles, but I would like to be able to hold 65 while going down the highway.
I am thinking of possibly changing the gears to raise my RPM so that I will have more power at a slower speed. My truck has the factory original 3.55 gears and I was thinking that switching to 3.73 or 4.11 would help. I don't want to spend a lot of money for nothing and I was hoping that someone here has had past experience that I can learn from.
Currently I am running 32" rear tires as opposed to the factory 30" If I go back to 30" it will be mathematically the same as switching from my 3.55 rear end to 3.73. So I may try this as a cheaper trial.
I can hold my speed better running the truck around 68-72mph much better than I can hold my speed if I slow down to 60mph. Engine RPM is the only way that I can explain this.
So what do you think?
  • Been there, done that. My experiences were initially towing a two horse trailer. I traded trucks to one with a larger engine, also gas, no help. If you are going to keep the truck, I would first go back to the 30" tires. Then try the 373 diff. Honestly, I don't think there is a fix for your problem, which is I went to a diesel.
  • When I bought my F250 last fall it came with the 20" wheel package & 3.73 gearing; I went down to 17" wheels & had 4.30 gears installed (under $2g for both diffs) and it made a night & day difference in performance.
    If you plan to keep your truck for years, I'd drop in tire size AND go with 4.10s or 4.30s.
    If you can foresee a new truck in your future, just go to smaller tires & skip the gear swap.
  • I think changing the tires and using a lower transmission gear is all you need. Can you lock out the top gear on the transmission? It is probably overdrive gear anyway. You should not tow over 65mph as the trailer tires are not rated over that speed.
  • I have plenty of power with my 6.7 L diesel, but I am perfectly happy running at 60-63 mph and would never dream of going 72. The tow is much more stable at lower speeds, trailer tires are rarely rated for higher speeds and you'll save a lot of fuel by going slower.
    After many years of going faster I find that sticking to the right lane at 62 or so is relaxing. It may take you an extra hour to get somewhere. But you will get there alive.
    BK
