Sport45
Apr 17, 2015Explorer II
If you run larger than stock tires it might make a difference you could feel. It would also give you a second OD when cruising empty.
I thought long and hard about putting an underdrive on my V-10 w/ 3.73 gears. Figured I could use the UD when towing (effectively a lower axle ratio) and turn it off when empty. As much as I thought about it though, it never made enough sense financially to shell out the money for one.
