carringb
Apr 18, 2015Explorer
Bedlam wrote:
The 5R110 was used on later model V10's and the 6R140 is used on F650 and F750 with the V10. You may have better luck matching up a newer Ford transmission than trying to get the Allison to work.
To use the 5R110 on an older V10, you have to do PCM, engine wire harness (or modify it by adding the missing pairs), and throttle body swap from an '05+ E-series V10. And after all that, you still don't get double-OD.
You can't put a 6R140 behind a 2-valve V10. You have to install a 3-valve V10. This is because Ford only uses integrated PCM-TCMs.
The Allison uses an external TCM, and it actually works fine with the stock Ford PCM because once you can select "Manual Transmission" from the Ford programming menu, it simply turns off its TCM.
