Scott16
May 14, 2013Explorer
narcodog wrote:
I never use that small cable thingy, they mostly junk. I just plug my into my gen with the umbilical cord,shore power. I don't charge my starting battery that way but I do use it to charge the other three battery's. If you run your genset and plug into the shore power cord you can run what ever 110 volt stuff you have, within reason.
This is for only charging the TC battery's correct. If you have an A/C you will probably have to run it only on low setting, and cut out some 110v Equipment, or not start the A/C at all. Just want to make sure for my own information.
Thanks,
Scott
44,056 PostsLatest Activity: Nov 19, 2013
