dbarrettExplorerFeb 07, 2016general wiring of ground or neutralFor new installation in my RV. I have a double pole double throw switch labeled L1 & L2, A1 & A2, B1 & B2. Please verify or instruct if I understand this. Run the hot from the breaker to L1. L2 is the...Show More
dbarrettExplorerFeb 07, 2016Also, the switch is a Bryant AC switch DPDT Center off 30A 120-277VAC. Dino
Related ContentAdding power outlets in slide with no wiringWiring A 30amp RV Outlet - Ground & NeutralWiring neutral/ground when splitting panel for MultiPlus?Fleetwood Angler wiringOpen neutral
