JimK-NY's avatar
JimK-NY
Explorer II
Jan 03, 2023
Generator Gas Storage
I have never found a good way to carry gas for my generator. I would welcome some suggestions. I rarely use a lot of gas, so a few gallons can last for weeks even in moderately high temps when I run the A/C and generator for an hour or so a day.
Currently I have a 2 gallon plastic container which just fits between the rungs of my ladder. This is for emergency only. I have only been able to find one container that fits the space and this one has a poor seal and spout. The spout is carried inside the container and every time I use it I get gas on my hands and dripping down the sides of the can. My go to can is 1 gallon that I store in a compartment. If it ever leaks the gas will flow under the shower pan and come out into the camper. I also need to leave the can outside for quite a while after I use it otherwise the fumes from gas in the spout or on the can will enter the RV.
  • I don't have a suggestion on the cans but rather on the spout upside down in the can when closed. Get a box of disposable nitrile gloves (available most anywhere) and put them on before fueling. Once done peel them off and throw them away.
    Don't even think about trying to burn nitrile gloves in the campfire. I tried that once and man did they stink.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    I store my 1 gallon gas cans in the front fenderwell. The storage space is accessible thru doors on each side near the front floor area. It's great storage that stays pretty dry, out of the sun, and has plenty of fresh air ventilation. You can see the drivers side door in this photo.
