badsix
Apr 26, 2017Explorer
generator mount
hi new to trailer towing and just bought a 27' 06 Fleetwood Pegasus. I also just bought a 3500 champion generator. my question is I would like to mount it on my rear bumper with a rack that I could ru...
badsix wrote:bobndot wrote:
Just because someone has done it and someone built a rack ???
IMO, its not a good idea for YOU to alter a vehicle that is being used on a public highway. Carry it in the TV where it can't fall off.
Who would you possibly trust to build you a strong enough bumper to haul that much weight on the rear of a TT that has limited suspension with no shocks.
I would consult with a liability atty before attempting this. Explain to the atty that you want to alter an RV to be able to carry a 130 lb.portable generator on the outside of a TT by modifying the rear bumper and you plan to haul it on the highway.
Regarding NIST Techical Note 1666 : Also..... Ask about using a portable genny on that bumper rack within the minimum distance of a building (your RV). (carbon monoxide)
Ask who would be responsible if a serious accident occurred ?
I can tell you it, its not going to be the mfg of the 27 ft. 06 travel trailer.
I wonder about your statement above about the (carbon monoxide).I can't see it being any worse than the Winnebago motor home I had years ago, that had the generator mounted under the floor and the exh. exited down under the home. i see new M-H with the exh. exiting either under or out the side, sometimes right near a window or door. i wonder why my situation would be so alarming.
Jay D.
