facory wrote:
The Honda or Yamaha 2000 watt inverter generator will run everything except the AC. My Yamaha runs the microwave with no problem. It may strain if the water heater is also running on electric, but I've never had a problem. If you think you'll need the AC but at least a 3000 watt unit.
I'd suggest two Yamaha EF2000s instead of the single 3000 unit. You can run them in parallel if you need to run the AC. They are easier to carry and if you are camping in colder months you only need to bring one along.
