PhilMac's avatar
PhilMac
Generator Options
Hey guys,
I am new to the travel trailer world and have some questions reqarding using generators. I have a 2008 Keystone Hornet 27DBS. I use it primarily for weekend camping at a hunting club. Our new lease currently has no power so I will be purchasing a generator. I am interested in the Honda EU2000. Will this unit be enough for the power needs of this camper? It is not a must that it run the ac since I will mostly use it in the winter. The onboard battery charger does not work, I have been using a small 6amp battery charger to keep the battery charged however it will not keep the battery at full charge. My plan is to install 2 new deep cycle batteries to help with that and I am also thinking about installiing a boat style battery charger that will keep them charged and then go into a maintenance charge when they are full. How many amps does the charger need to be able to put out to be able to run lights, furnace and a few other things? Also, with this camper plugged in to a generator will the wall outlets work? Any help will be greatly appreciated.
  • Hi,
    Replace the converter if will be far more effective than a battery charger if you get a 3 stage unit.
    Forget about the air conditioner unless you spring for a Magnum hybrid inverter/charger. If you get one of those then a single 2000 watt generator will run it fine.
  • The 2000 will run rig except for air conditioning. It may have problems with microwave if other major 120 volt items are in use.
