deltabravo
Aug 30, 2020Nomad
time2roll wrote:
I recommend a smaller generator that you can just lift. Honda 2200 would be a good choice. If you need to run the A/C get a Micro-Air start kit if needed.
Ditto.
Or add a second EU2200 and use them both to run the A/C reliably. Only use one for small loads / battery charging.
Lock them up under a hard truck bed cover / tonneau cover or topper (canopy, or whatever they are called in your region)
Or buy a travel trailer with on onboard genny. Outdoors RV Backcountry Series has gennys.
I came very close to buying this one. Video Tour:Outdoors RV 24KRS
I'm pretty partial to Nash / Arctic Fox / Outdoors RV because they build their frames in house instead of using junk from Lippert.
Video tour of the ORV Factory
