valhalla360
Sep 04, 2018Navigator
No guarantee a popup will have a smaller air/con...it's a smaller volume but worse insulation...probably more important, units bought in bulk likely would see no cost savings to the manufacturer by going lower BTU.
We have a Yamaha 2400 that will run out 15k BTU air/con but it's marginal. If it was a smaller 5-9k BTU, a 2000w unit (typically 1600w continuous rating) might do the trick.
Really you need to find the specs on the unit you are looking at both running and startup load. If it's the startup load that's the problem they have capacitor systems that help reduce it.
44,025 PostsLatest Activity: Feb 18, 2025
