PAThwacker
Sep 12, 2018Explorer
SoundGuy wrote:SoundGuy wrote:trx680 wrote:
I posted this here because I'd imagine the pop-up campers would have the smallest A/Cs.
What size generator is required to run your small A/C ?
The most common size roof mount A/C, regardless of what type of rig it's mounted on, is 13,500 BTU. No longer though does one need a 3000+ watt genset to power one of these units - invest in the new Honda EU2200i inverter genset, equip the A/C with a Micro-Air Easy Start Soft Starter Kit and you'll be able to successfully start & run any typical 13.5K BTU A/C even when the temps exceed 100F and elevation is well above 5000'. Many are now doing this successfully, there's no need to rely on outdated information from those who aren't up to date on the latest technology. :R
If you really want A/C to be effective in any trailer with tenting the key is to retain as much of that cold air inside the camper where it belongs. You can do that by making Reflectix window inserts which will significantly reduce heat load the A/C has to deal with.
Number one purchase is popup gizmos that cover the bunk ends. Even with a 13500 on full blast the bunkends are 90's in direct sun. Cover them, have the awning face south and park under a tree.
44,025 PostsLatest Activity: Feb 18, 2025
