HarryBB's avatar
HarryBB
Genrac Inpact 36 lp - Sleepy Help
I have looked at prior threads - in particular Sleepy's comments back in 2009. Hopefully I'll catch him in a good mood...
1. Generator ran fine last weekend - but battery was weak so I replaced it today.
2. Reversed polarity and blew a couple of fuses but replaced them.
3. Tried to start generator after replacing 7.5 A fuse by "local" start switch on generator... Just getting a click and the gen tries to turn over but doesn't quite get er done.
4. It's in a 2003 1121 - build Oct 2002 - kin to Sleepy 1121. What were the symptoms when you - Sleepy - "wore out your starter"? I wonder if I have the same issue - but only 140 hours on set.
  • AITG - I have meters.
    Where is the circuit board you mention?
  • OK - Thanks for the feedback.
    1. I do not think this is a fuel driven issue. All other systems requiring delivery of propane are functional - WH/Fridg/Furnace/stove.
    2. All systems - lights/stereo etc. - operate on 12 VDC without shore power and with.
    3. Generator does the same thing whether connected to shore power or not. Just clicks - loudly - but seems like there is no "turning".
    4. Given I made the most basic of rookie errors and reversed polarity on everything when I installed battery - requiring a number of fuse replacements including pulling my stereo out of the wall to get to the onboard fuse there - I have to believe I bollixed up a) some starter sensor, b) the solenoid, or c) the starter itself. (Additional observation is that the rubber cover over the cable entry points appears to have some heat damage.)
    5. I already replaced the 7.5A fuse in the face of the generator - next to the flip switches to shut down output) and have tried starting with and without the flip switch engaged - IE with and without load - same result.
    I'm not an electrical whiz - my ordinary solution is to replace fuses with pennies and if you don't smell anything you are good to go - but I'd bet on one of the three options under 4 above.
    I just happened to be online this morning... waiting out a storm front NE of Cincinatti, Ohio.
    As I'm sure that you know the suggested 30 minutes of run time per month would have used 60 hours of your 140 hours total.
    I very seriously doubt that you have starter problems... I had a thousand or even many more hours
    A srong battery is required for starting our remote controlled Generac propane generators. Is your new battery(s) fully charged? Turn on your trucks engine... that will add a little power while you try to start the generator.
    Your generator has circuit breakers on the face of the generator.... you have probably already flipped them off and reset them. The generator should run with them off. (No load)
    And since you tried starting the generator from the switch on the generator?
    Have you checked the heavy wires where they are joined on the threaded posts... maybe spray with WD 40 and tighten.
    While your problem sounds electrical... Are you sure that you are getting propane? If the generator just wouldn't start until the house batterys ran down..
    I always light the stove in the camper just to make sure that we have propane all the way through the syatem when I refill my propane tanks.
    then... I'd look first at the "Carborator... there is a flimsey little rubber tube that can cause problems...
    and last... a crimped propane hose. The hoses have a lining that can crimp while looking normal on the outside.
    You should PM... my cell phone gets the PMs...
    I'm traveling at the moment.
    Chet
  • Do you have a voltmeter? There are a couple of simple things you can check. I went through this last year - ended up with a new circuit board.
