toedtoes
Aug 02, 2021Explorer III
The towing capacity is only one part of the equation. You also need to look at the payload and potentially the axle and tire ratings.
Know that when you post those numbers here, you will have folks say you can only tow a tent trailer and some who will say you can tow that class A. ;) So, you need to weed through those, ask people you know and trust who are familiar with towing, and maybe take a few test drives towing yourself in order to determine YOUR comfort level before buying.
As mentioned, do not trust the RV salesmen to know what is safe to tow and what is not. Most have never towed and have no knowledge.
Once you know what you can safely and happily tow, you will most likely have two numbers to work with: the actual max tow weight and the max tongue weight. The max tow weight should be compared to the GVWR of the trailer NOT the dry weight. The max tongue weight should be compared to 10-15 percent of the trailer's GVWR. The dry weight means nothing.
I recommend not looking at floorplans until you determine your weights. Otherwise, you or your wife will fall in love with a trailer that you cannot tow with your Tahoe and every trailer within your weights will fall flat. Sort of like looking at houses without your max purchase budget - what you can get will look dinky.
