Kayteg1 wrote:
SidecarFlip wrote:
I've consider that myself. My truck is so old I'd have to fabricate a mount. and it would have to be hinged so the tire laid down on the ground to remove it from the mount.
Come-on Flip. You are fellow metal fabricator and you can do that.
For my 2000 F250 I made a clamp on factory tow eye so 1 lb of steel, 1 big bolt to clamp it and about 1 hr of work.
I would advise the idea to each TC owner who drive SRW.
The spare wheel moved from behind rear axle onto front bumper took close to 300 lb from rear axle, so sure increased safety and handling, even if it looks Redneck ;)
Kayteg..
My issue is, I don't have the stock suspension on the old girl. I extensively modified the front and rear suspension many years ago so to fit a front spare tire carrier would entail a bunch of fab and welding work and I'm getting old and don't want to.
I did an axle flip on the front and got rid of the front swing shackles with a fabricated weldment that runs across the frame ends. The truck sits high, 6 over stock. Kind of wish I didn't do it now, it's a pain to get in and out of even with steps. My wife has to use a step stool to get in. It did really improve the ride and handling. The old F350's rode like tanks with those huge stack of leaf springs. I have 7 leaves in the back and 5 in the front on each side. It's a tank by today's standards. Made all the spring pivots greaseable too. Added Thompson linear roller bearings in each pivot point in place of the stock rubber bushings. 15 zerks just on the front end. 4 more out back plus the driveline.
I may anyhow this winter. I have the steel in the barn to do it. Looked at making one with a winch mount and tire carrier and it would get the weight from the back end even though my tire and wheel assembly isn't that heavy with the Alcoa forged rims.
Never planned on keeping it for 20 years back then.
Probably should get a new one but I don't want the DEF and all the headaches of the pollution hardware. Mine has no pollution hardware at all and she does 21 with the camper in the bed.
Besides, a new truck cost more than I paid for the farm.
