LarryJM wrote:
I mounted a Wheel Masters "Master Level" to a thick rectangle of plexiglass and then used two of the large 3M magic adhesive strips for wet locations and for the last 7 years it has been fine. I did put some sealant around the edge of the plexiglass to hold it better. The thick plexiglass was necessary to melt the nuts into the plastic so the back was flush and could be mounted with the adhesive strips and not have the nuts sticking out from the plastic.
Larry
Larry,
Post a pic..this sounds really good and I'm a visual learner
Thanks.
