travelnutz
May 21, 2014Explorer II
To me it's just an expensive un-nessary slide feature that can have nothing on the walls or ceiling in the slide overlap area which eliminates storage compartments etc in a the already very cramped interior. With the slide in, you crawl thru a little hole in the wall inside the exterior door! Are you kidding me? I child's playroom at best!
The slide feature makes the interior width and height even less due to double walls needed for the sliding wall design and also the roof and maybe the floor too. It does nothing but add problems which the same length fixed length coach structure with non-slidout design would not have. A fixed length extended teardrop design would only require a 12" to 18" longer tongue length for having a fixed length turning ability without the trailer body hitting the back of the tow vehicle and it would actually weigh even less and cost a whole lot less. Me thinks somebody's been smokin some really good potent stuff!
The loss of interior room when the slide is in along with the air, dust intrusions, and water leaks etc that come with the trailer's aging plus so many other deficiencies make it almost insane. The slideout feature on teardrop shown does nothing really for the teardrop since the tongue has already been lengthend to make room for the slide length to rest on when out! So much money and non-commonsense wasted!
Please give me a hint as to what the heck a slide on a teardorp is good for? A hard sided folding A-Liner type design makes a lot more sense as it is about the same size, fuel mileage, and weight as a teardrop but you can even stand up inside it. About 30 seconds to go from folded down to fully opened and that's about how long or longer to open the slide on a teardrop. Probably cheaper also!
